Cannot boot to windows
Can anyone tell me what “critical-process-died” means? That is the answer I get when trying to start my computer.
좋은 질문입니까?
좋은 질문입니까?
The computer may have a virus. Run a virus scan program using safe mode. If there no virus, update device drivers. If you cannot, let me know if I can provide help by step by step using this application
이 답변이 도움이 되었나요?
Do you also have a problem of it doing anything after logging in if so your hard drive has died I would recommend upgrading the ram to at least 8gb and put windows 10 I know that it would work mine is running it now because I had the problem of logging in then everything just dieing the only thing is it would be a bit slower than normal
이 답변이 도움이 되었나요?
Hello @a123bonnie
If you have the chance to start your device in safe mode to test if the issue is with a recent installed application or if that let you login you can check the system opening the CMD with admin privileges and use the command sfc /scannow, to check the OS.
The error you mentioned can be happening due to so many factors but you need to discard if the issue is only with Windows OS or maybe there is a problem with a hardware component. Another good command that can help to check your computer is chkdsk /f C: to verify if your HDD is ok and no sector issues detected.
If you are able to start in safe mode, you can use System Restore to get back your OS at an older state point were you be sure the system was working correctly.
Test it and let us know,
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 178
