Can the iPhone 4s camera be installed in the iPhone 4?
Just as the tittle says.
Can the camera be installed on the iPhone 4 to "upgrade" the camera?
좋은 질문 입니까?
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
평판: 1
Just as we expected, the connector for the camera on the iPhone 4S is different than the connector on the iPhone 4 (CDMA and GSM). This means that you cannot "upgrade" your camera in your iPhone 4 (or downgrade your 4S if for some odd reason you can't handle the 8 megapixel camera). The iPhone 4S connector has more pins. Even if it did fit, I don't think it would work anyways.
iPhone 4S:
iPhone 4 (CDMA and GSM Side-By-Side):
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 3,142
I think it will be different since they changed it quite a bit. We'll check that out when we do our teardown.
Scott Head 의
agreed, too early to tell. from what I know about apple components, most likely not.
hectordtruong 의
Do you know who the manufuacturer of the camera is? The world is waiting...
bob cooper 의
