주요 콘텐츠로 건너뛰기
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 질문 전체 보기
My screen has liquid in it.
So I have a TI-84 Plus CE that was sitting on my desk, and a closed container of isopropyl alcohol fell onto it. I didn’t think anything of it. Now, I noticed (it’s been a couple of days) that my TI had white residue all over the bezel. And to my horror upon turning it on, the entire polarizer is soaked and the screen is extremely dim. What do I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Most likely you will have to get a new screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First, I’d suggest immediately taking apart the calculator and cleaning up what you can to avoid more damage. You can remove the LCD by flipping up the white connector (seen here) over the ribbon cable using a fingernail or flat head screwdriver to release the cable. This may make it easier to see if you can repair what’s left of the LCD.
Unfortunately, replacement parts are extremely difficult to find because TI doesn’t sell them separately. If your calculator is less than a year old you may be able to use your warranty to get a replacement but otherwise you’ll either have to buy a donor calculator (hard to find) to get a display out of, or just buy a whole new calculator.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Matthew Jones 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 121
