MacBook reboots on its own, fails to boot, etc problems
Hi there,
Similar to boot up sceen white with file and? flashing, I’ve went into recovery and attempted to repair the drives using First Aid. All results returned that that drive seems to be ok. But I’m still getting system reboots, and sometimes file folder with question mark flashing. I’m still able to boot into macOS sometimes. After which there is an error message (I’ve been seeing different errors each time). Some include:
panic(cpu 2 caller 0xffffff8004814e67): "AppleS1XController::setPowerState(0xffffff8017a7d800 : 0xffffff7f875dabc6, 3 -> 2) timed out after 100734 ms"@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-6153.141.1/iokit/Kernel/IOServicePM.cpp:5296
Backtrace (CPU 2), Frame : Return Address
panic(cpu 2 caller 0xffffff7f883f0231): nvme: "Fatal error occurred. ID=-1 ARG1=0xffffffff ARG2=0xffffffff ARG3=0xffffffff. FW Revision=5.844.01\n"@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/IONVMeFamily/IONVMeFamily-470.100.17/IONVMeController.cpp:5320
panic(cpu 2 caller 0xffffff8002c8e17c): Sleep transition timed out after 180 seconds while entering darkwake on way to sleep. Suspected bundle: com.apple.driver.AirPort.BrcmNIC. Thread 0x74.
Failure code:: 0x01769573 00000031
I suspect that the SSD has failed. Can anyone help? Thanks!
Regards,
Kong
좋은 질문 입니까?
