iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
좋은 질문 입니까?
좋은 질문 입니까?
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
해당 답변은 도움이 되었습니까?
Thanks for the info will work. ;)
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 271
댓글 2개
have you tried a replacement screen at all?
Jade Richards 의
I'm not I thought it was the battery
dimit1r89 의
