주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
327 질문 전체 보기
Display issues when lid is fully open
My macbook has developed an issue where areas of the screen that are solid black are not displaying properly, it’s hard to describe as it’s a bit inconsistent, but for example bold black fonts are hollow and the black screen saver is a weird flickering mess. Only happens when the screen is open past about 20 degrees.
Is this a known issue with a reasonable fix or do I just have to go to the apple store and beg for mercy?
EDIT: Images added. Both are of the same screen only difference is changing the lid position.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Can you post some pics and/or a vid so we can see things 기존 질문에 이미지 추가하기
댓글 달기
답변 2개
선택된 답변
For future reference. I don’t think the problem I had was with the horizontal sync but was a ribbon cable issue similar to the one described in this article https://www.ifixit.com/News/12903/flexga.... Not that it matters much because the solution is the same replace the whole screen.
I decided to try my luck and took it to the Apple store. To my surprise the lady there immediately identified the issue as a display cable issue that was replaceable under warranty (in Australia at least) and for good measure they would replace the keyboard AND BATTERY. The only condition was that the moisture detectors inside hadn’t gone off. If they had it would have been an AU$1500 fix.
So now here I am with a refurbished laptop, new screen, new keyboard and battery for absolutely nothing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@dave797979 - Well I'm happy you got a free repair! Austrian warranty coverage is a bit different than here in the states.
To clarify, the issue was not the FlexGate backlight issue which was a cable issue.
댓글 달기
가장 유용한 답변
OK, I get it! Your horizontal scan is shifting. So as an example
The text smears as well as any vertical line.
This is a sign of a bad T-CON connection either the ribbon cable is failing or the solder joint of the cable is. Here’s a breakdown of the connections
The pink cables are the video cables to the LCD panel which are soldered to theT-CON board.
Sadly you’ll need to replace the display assembly MacBook Pro 15" Touch Bar 2017 Screen Replacement. Sadly, the part is hard to get used. Here’s one source for a new unit
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
David Young 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 747
