주요 콘텐츠로 건너뛰기
PowerBook 100 Series는 Apple의 PowerBook 라인의 시작이었습니다.
Macintosh PowerBook 145 Screen Issues even after recap
Hi all.
I recently got a PowerBook 145 with startup sound chime, but black/grey screen (only the backlight worked).
So I decided to recap the creen board (I used 9x 3.3uF-63V capacitors instead the 35V original ones) and the inverter board with a 47uF-16V and 33uF-16V (tantalium) caps.
The problem is that, even with this cleaning with alcohol and recap, the display doesn’t work properly… now it turns whit and shows a series of vertical lines, but nothing else.
Is the display definitely broken?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Without having a second PowerBook which you can use to check out the display on all you can do is check the voltages.
My first Mac laptop was a 180c which I used for work, it was much lighter than my Compaq Portable III ;-} I had been using. And the screen was full color! The Amber screen my Compaq had was hard on the eyes!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
lumia.nicola 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 392
