주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Why won’t my phone turn on?
I just replaced someone’s iPhone’s battery. Everything seemed to go smoothly. The phone booted up, took a charge, and loses battery at a consistent rate. However if I let the phone drain fully and I try to recharge it, the phone simply won’t turn on. This problem has happened both on this 6s as well as my own 6. I’ve gone through 5 batteries overall with the exact same issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Always use original parts in replacements. Every product has a specific design and working profile set by its company according to devices.
When you plugged other brand battery first time it may be short your motherboard IC. As describe above by Shawn, check your mobile board. You should also check your charger. Might be the charger is not working well, and you are changing your batteries.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Was it a good quality battery? Never have seen this, maybe you have recieved poor quality battery. Try from differrent supplier.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I've used 2 types of batteries so far. One was from a mall repair chain I used to work in. The second was from Fixez. I presumed the Fixez battery worked since I actually used one on another 6 in the past (not the 6s or my 6). This iPhone never had the issues I've described. The 6s I have now is currently using the Fixez battery.
Then i think it need a board level repair, something is wrong on logic board that prevent the battery to drain fully empty.
댓글 달기
With the Iphone 6s it has a known issue with the wifi IC shorting out internally. It will need a new Wifi IC and have Nand removed and wifi unbinded. Motherboard issue 100%
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Does this problem also occur on the regular 6? I've had the same issue occur in the past with regular the iPhone 6.
댓글 달기
귀하의 답변을 추가하세요
Alex Guerrero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 8
전체 시간: 73
