주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Home button / battery fire
Changed battery on my cousin’s 6s plus ….. it was damaged and actually caught on fire when removing it. I quickly got it out of phone , it appeared not to do too much damage. Some scorching in the left corner around and on headphone jack . I cleaned it up put new battery in , put it back together powered up everything worked EXECPT home button ….. top screen / home button was not on/near battery when it caught on fire … do I need to change charging port / headphone jack assembly….. or something else like change the entire back assembly of the phone . Need some ideas or help on what direction to go
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If you didn’t remove the actual home button I would make sure the connector is seated properly. If it is than you have most likely damaged the flex cable or nudged a tiny component around the connector. If it is a damaged flex you will need to replace the screen.
The charge dock has nothing to do with the home button.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Thanks, Chris …..The reason I asked about the port and the surrounding area is , because in reading one of the other posts , talking about the home button , someone mentioned a broken or bad ( in my case melted ) connection causing a continuity problem that affected the home button. …. I’ve removed and reconnected everything multiple times. And when the fire took place the screen and button where 4 feet away, so the fire couldn’t have damaged the cables or connectors. Not to say I might have when I removed them with spudger . Is there anything under the headphone jack orTaptic Engine that could cause this issue? Like a ground wire or a ribbon cable …..any or next idea please
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joe Hoy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 105
