주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
upgrading the Mac to 1 TB SSD
Hi Folks!
Hope you guys are staying fit and healthy.
I have a MacBook Pro Late 2013 15” Retina model (8GB RAM, i7, 2.0GhZ processor with 256 GB flash drive).
Can I replace this flash drive to 1 TB NVMe 2 SSD (with the below converter which is compatible?)
Will it have any performance impact or will it support 1TB without flaw)?
By the way, I am planning to buy Crusial NVRam SSD.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Here's a good reference on the custom Apple blade SSD's The Ultimate Guide to Apple’s Proprietary SSDs
댓글 달기
답변 1개
Your system can support either a PCIe 2.0 x2 or PCIe 2.0 x4 NVMe SSD.
Your options is getting a real custom Apple SSD (made by Samsung), getting one of the 3rd party SSD’s made by OWC or Transcend. While these tend to be more expensive, they also stand behind their gear.
While some folks have had luck with M.2 SSD’s with an SinTech adapter. I personally don’t recommend them. I’ve taken quite a few out as they tend not to hold up and they do have a few issues with sleep mode as they don’t have the Apple interface lines nor the logic. Often you’ll get stuck in a passing the buck problems between the SSD and the adapter makers.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Avinash™ Kumar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 50
