주요 콘텐츠로 건너뛰기
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 질문 전체 보기
Lacie d2 Quadra Hard Disk won’t power up
I have an old Lacie drive that uses a 4-pin (circular) plug connection from the power supply bar to the hard drive. The power bar shows a steady green light until I connect its 4-pin plug to the lacie drive; then the green light flashes intermittently & fades in colour. The drive won’t power up, so I assume something is wrong with the receiving end of the 4-pin connection. What can I do to fix this, or to recover the data from the drive before I recycle the device?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Here’s how to remove the drive:
https://www.youtube.com/watch?v=n9SaTPkb...
To scan the use a universal adapter to hook the drive up and recover your data:
Universal Drive Adapter
Universal Drive Adapter 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
Thanks very much for that information. Mine is quite a bit different than that one on the inside (mine may be an earlier model?); and the universal power adaptor would need a 4-pin (DIN?) circular plug to power this drive. However, I am suspicious that my power adaptor may be fine, but that the receiving end (in the hard drive case) might be where the failure is. If there is a way to bypass the power receptor in the hard drive and access the data, I’d be happy. (I did try another power adaptor, but it did not work, so I suspect the problem lies in the small black box that houses the power port on the hard drive.) Is there a way or a work-around to get at the drive’s data that would bypass the faulty connection?
Oh gosh! Now I see what you were intending with that universal adaptor!
Thank you!!,
I have the same problem. Could you explain what was intended with the universal adaptor? I didn't understand how the video could help.
댓글 달기
귀하의 답변을 추가하세요
JOJO 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 25
전체 시간: 778
