주요 콘텐츠로 건너뛰기
Mac mini가 오랜 기다림 끝에 새로워졌습니다. 프로세서 옵션에는 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5 및 3.2GHz 6-core Intel Core i7 프로세서가 있습니다.
85 질문 전체 보기
My 2020 Mac Mini not reporting correct memory
I just finished installing the 32 GB upgrade to a new Mac Mini 2020/2018. Only difficulty was re-installing the antenna cable (not the screw, the cable). Tiny fingers help.
But I do have a problem - Ordered the memory from Crucial (as I have for years…decades? For a variety of computers). Installed a single 32GB SO-DIMM in the slot closest to the center of the device and removed the 2 x4 GB SO-DIMMs.
  • But the About Mac is still reporting 2x4 GB in the 2 slots.
Rebooted a couple times, no change. Very strange. Anyone got any ideas?
BTW: Writing this on the Mac Mini, so it does power up correctly, and connects to the internet correctly.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I would try resetting the systems NVRAM (PRAM) and SMC systems to see if that helps How, When, & Why to reset the PRAM & SMC on your Mac
You may need to move the SO-DIMM to the other slot.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Turns out that "sleep" is not the same as "reboot". Old habits, I rarely shut down my primary system. I did the "reboot and hold down D" and things are fine.
thanks
댓글 달기
귀하의 답변을 추가하세요
bfc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 61
