주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Home Button not working
Perhaps someone can help me. I just disassembled mine and got to the very end. I can't see anything wrong with my home button. The Apple tech said it was just some prongs that needed to be bent back, but I don't see anything like the prongs. My home button stopped functioning completely. Should I just replace the entire home button and ribbon, or should I replace something else, or are there really a couple of prongs that need to be bent back?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly.
댓글 달기
답변 1개
선택된 답변
I just replaced mine, there are no prongs. It's the entire home button and ribbon that need replacing. It's all one piece.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks. That worked. Extremely time-consuming and by far the most difficult task I've ever completed, but it works perfectly. (I commented on this above, before it was an answer, so it shows up twice.)
댓글 달기
귀하의 답변을 추가하세요
jkgarrett17 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 837
