주요 콘텐츠로 건너뛰기
How do I fix a sunken in lock button?
Hello everyone! My girlfriend recently came across an annoying problem with an iPod Touch I gave her. The lock button appears to have sunken in, and is now flush with the frame of the iPod. She told me that it was sticky before it finally sunk. I know how to take the front panel off the iPod, and I have tried to pry the switch out without opening it. Do I need a new switch? Or do I need to pop it open and push the switch up?
Sorry for the wall of text. Thank you!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
If it's like the 2nd gen touch then the switch is held in place by two screws. You'll have to take the top circuit board off to get at those screws. You may even have to take out the LCD panel if there's not enough room. If one of those screws did come out it's a good idea to get the ipod open ASAP as that screw could cause an electrical bridge and short out a board.
here's how to get that top board out.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Ok, thanks alot. I'll get on this as soon as I possibly can. I'll keep you posted on the results
댓글 달기
remove the glass by prying it up with a plastic tool, 4 clicks on left and right, one on top, 2 on bottom, careful not to crack it, before lifting it up, unplug the cable in the top left. you can unscrew it from there and adjust it. then screw it back in
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 6,349
