주요 콘텐츠로 건너뛰기
A1708 / EMC 3071—2016년 11월 출시, 이 MacBook Pro 13”는 OLED Touch Bar를 소개합니다. 듀얼-코어 "Skylake" Intel Core i5 CPU 및 Thunderbolt 3 포트 4 개 포함.
239 질문 전체 보기
audio is distorting randomly
Out of no where the audio will sound all distorted and it will eventually fix its self. With windows I would delete the driver and reload. not sure what to do for a Mac. I have a recording but my phone recorded it as a m4a. now sure what to convert it to?
**When it happens again ill just record a video rather than doing the voice memo
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Check your drives free space as well as your available memory. Your issue is often caused by not having enough drive free space or RAM.
I would free up at least 1/4 of the drive so the OS and apps have elbow space so the garbage collection process isn’t firing off as often.
RAM is tricky! While you may have 16GB, you may in fact have over allocated your physical RAM and are using Virtual RAM which is based within your drive! Once again we run into the drive storage issues! So reduce your application load. As an example, don’t open so many tabs in Chrome, each tab holds RAM!
I would get a good resource monitoring app to track RAM and storage usage. You can also use Activity Monitor but it does take a bit more effort to comprehend.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I’ll look in to this. Drive space isn’t a problem. I have 181gb free of 250 so perhaps it’s ram issues. Can you recommend an app I can use?
WindowsServer is second highest culprit right under Safari for ram about 830MB safari is 850MB and is highest. Only three tabs open in safari. If I go to cpu in activity monitor WindowsServer is right about 50% usage but that fluctuates. As I’m staring at it it’s up and down sometimes as low as 1.8%
Thanks?
I personally use StatsWidget+
Monitor your network if you are accessing the file from the internet or your external drive as that could also effect the playback timing as well.
댓글 달기
귀하의 답변을 추가하세요
Carlos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 51
