주요 콘텐츠로 건너뛰기
Guides and repair information for JBL speaker systems, desk speakers, and ipod speakers.
Partybox 200 won't turn on anymore
Hello,
I have had the JBL Partybox for over a year now and suddenly after pretty light use, it just stopped turning on.
The Power light illuminates orange so i know its getting power, I have opened it up and made sure all the ribbon cables and connectors were snug. I also have re-flowed and measured the power switch on the circuit board just to make sure it’s not the switch.
I can’t test any sort of power or connection since I can’t turn it on unfortunately.
I can’t seem to find anyone having the same issues as me so I am hoping I can find some help on here! Thank you in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 8개:
Same problem. Someone please help
Same problem with my JBL partybox 200
@florentino80661 what have you checked and what have you tried? Tried a factory reset? Checked your circuit boards? Checked your power supply? Checked the battery?
Almost 1 year later, I'm here with the %#*@ same issue.
Sorry for waking this topic up guys, I don't really like doing it but since it's literally the same problem on the same device...
Mine didn't have the red light, but the ribbon going to the plates was disconnected. Great, I reconnected it but now it stays orange.
With only my eyes, I couldn't see any burnt surface on the board (and it costs 130$ please let me out of this 😂)
But on the alimentation plate, I can heard kind of a whistle... I don't know if it's normal but why not.
What could I do ? Do you need anything more ?
Thanks in advance
@onelots you have checked the "no-Power" flowchart and checked the voltage on FB40? You've tried a reset? Post some good pictures of the "alimentation plate" so we can see what you see and hopefully we can figure out where the sound comes from. 기존 질문에 이미지 추가하기
댓글 3개 더보기
댓글 달기
답변 1개
@lindseyclark19 @danmtg @florentino80661 yes, the original is an old question but maybe we can still get this fixed. To start off try something like this
Tried something like this:
Connect the JBL Partybox to the Power Outlet.
Press and hold the Power Button for 30 seconds.
Disconnect the JBL Partybox from the wall.
Press and hold the Power Button for another 30 seconds.
Connect the speaker to the outlet.
Press the Power Button once to turn on the JBL Partybox
I would also try a factory reset. {https://thedroidguy.com/how-to-fix-jbl-p... |this here] should also work for the 200
Next you would need to start checking for the power situation. You all said that you have identical problems, so I suggest that you all check the voltages according to this
Let us know what you find out. Also, post some good pictures of your boards etc. so we can see what you see. 기존 질문에 이미지 추가하기
To get to your boards etc. use these images for the disassembly
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hola todos, tengo el mismo problema, pero indagando encuentro que no tengo los 5v sys que van desde los ic U1 y U58, si alguien pudiera confirmar nos ayudaría
댓글 달기
답변을 추가하세요
Linzi Clark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 1,820
