주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
Camera not working after display replacement
Hi, I’ve just replaced my LCD screen assembly, making sure the battery was disconnected while I did this. However, the camera does not work even though the rest of the screen works perfectly. The suppliers for the replacement assembly assured me the camera was tested before it was sold to me. Please help!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Hi, I faced a similar problem after assembly replacement for A1502, I got it done from technician (not service centre who also sold me the same) , camera did work for first time after reboot, for around 3-4 days, then ended up showing no camera connected for another 2-3 days, then again worked few days later. Right now it has again stopped to show up on system report and shows error" not connected to camera "while on apps.. Apparently I visited the technician again he cheked for the assembly in his system.
Surprisingly, Camera worked without fail for several times after multiple restarts also. Probably the assembly is not faulty, but what for I am facing the issue...how can I fix it? The tech guy says my motherboard is screwed up or something...please help me...
댓글 달기
답변 3개
가장 유용한 답변
Sadly, you either have a bad connection or have bad display assembly. Here’s a breakdown of the display ribbon cables:
Photo credit: @just1ed www.macplus.sg
See if reseating the cable fixes things other wise you’ll need to get a exchange.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
While my Mac experience is limited, my first thought would be to check if the device is showing up within their version of Windows’ Device Manager. If it’s in there, the machine should at least be acknowledging that it exists and is connected, if not, the machine is likely not recognizing it as physically connected and I would suspect that if the camera is indeed not defective, then it may have either a loose connection or was not connected correctly again during the recent screen replacement.
Were the entirety of these steps followed during the screen replacement, especially those related to disconnecting/reconnecting the antenna and cabling leading to the screen? MacBook Pro 13" Touch Bar 2017 스크린 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The screen may not be defective. The touchbar model (A1706) and the function key model (A1708) should have interchangeable screens. Have you confirmed that the board is not the problem? Was the previous screen webcam working? I have seen them not work from both ends. When it comes to screens the eee code is everything. Its the only 100% way to guarantee compatibility.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@iseanlove - The system is the function key model and it’s display assembly is physically different than the TouchBar models.
댓글 달기
답변을 추가하세요
Zac Dawn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 30
전체 시간: 5,725
