주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
660 질문 전체 보기
Phone battery draining FASTER after battery replacement.
I had my phone battery replaced today because for a while it had been draining fast and it said it was at 78% performance and I should have it serviced. Since I got it back, it says 100% peak performance, but the battery is draining faster than it ever used to. I was surfing the internet as usual, no videos playing no images, just reading on websites I frequently use, and I watched the battery go from 75 to 35 in one hour. This never happened before. Bluetooth off, WiFi on and connected, full brightness (as usual), and nothing out of the ordinary (also no other apps on). What’s going on?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If the new battery is draining a lot faster than the old one it is probably a bad battery but I do see this on some new batteries and calibrating them sometimes fixes the problem.
 I would suggest leaving it to charge overnight than run it down to it switches off than leave it to charge up again. If it is still draining quickly I would return the battery for a replacement.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks! Will do.
댓글 달기
Chios, If your battery drain quickly after replacement then there most probably you have installed any third party battery in your system mostly these local batteries doesn’t work properly. If this is not the case then there maybe any software related issue in your phone.
How to fix iphone battery draining fast problem
I can refer you this article this will help you in solving the software related issues which is draining your phone battery you can use these in android system too.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John Romano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 15
7일 전: 126
30일 전: 476
전체 시간: 6,338
