주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
Screen flickering after a few hours of use
I’ve had this issue since about October this year, when I updated it to Catalina. It’s fine for the first two hours after I boot it up, maybe a tad of “burn-in” or image retention in the top tool bar. After that, I get flickering lines going vertically and the top of the screen turns purpleish. Image retention as well. It’s gradually becoming worse and worse as well. I’ve heard that a few others have gotten this issue. Is Apple refusing to acknowledge it?
I had the battery and keyboard replaced in 2019 due to known problems. However, the battery has gotten worse now as well. Only 146 cycles (I don’t use this much) and 78% capacity. Would I just be better off selling this computer as parts rather than repairing it? Or could I get a separate monitor for it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
Bumping this, really need an answer!
@danj Any idea on this one?
@welchd - Sorry got busy on a project and this slipped by.
댓글 달기
답변 2개
가장 유용한 답변
I would first double check to see if the issue is visible on an external display if it is then your logic board has issues otherwise you have a failing display.
The T-CON logic clocking is drifting so the horizontal scan is jumping up and down giving you this odd blur effect. You’ll need a new display to fix this:
You might be able to get a recycled part which would be cheaper, right now they are hard to find.
And here’s the guide to replace it MacBook Pro 13" Function Keys 2017 디스플레이 어셈블리 교체
이 답변이 도움이 되었나요?
점수 2
댓글 달기
did you try buying a new battery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
JOHN DOE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 1,308
