주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why is the analog stick jittery, erratic, or jumpy?
I purchased 3 of these controllers and all 3 have trouble with a jittery right analog stick
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
선택된 해법
If you are using a tool like this https://gamepad-tester.com/ and notice that one of the joysticks/analog sticks are moving erratically, here is what I did to solve the problem:
  1. Take the controller apart (completely remove the board from both shells)
  2. Remove the plastic part of the analog stick (it slides right off by pulling it up)
  3. Pour/squirt isopropyl alcohol into the analog assembly, and wiggle the metal stick around to work it around the inside.
  4. Let dry for a moment, plug the board in, and test. If the erratic behavior is resolved, go ahead and reassemble the controller, if not, unplug the controller, repeat step 3, and try again.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I tried this on my PDP Xbox One controller that had a jittery left analog stick (the potentiometer for up/down would jitter down erratically with the slightest pressure in the up direction). At first it didn't work, but then I slightly cracked open the white cover of the potentiometer from the top by pressing in the little clips on its sides and using my fingernail to crack it open from the top so the wires were showing, then wash with automotive degreaser, blow with compressed air = jitter completely fixed!
의
댓글 달기
답변을 추가하세요
Nelson Hardy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 10
지난 7일: 30
지난 30일: 109
전체 시간: 16,938
