주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
No modem firmware and stuck on searching
Hello, my iPhone 5s shows searching after booting up and after 30 seconds it says no service or sometimes Cellular update failed error. I checked the about page in Settings-General and it does not show modem firmware but it shows IMEI. When I go to the phone app and dial *#06# just nothing happens. I remembered that my phone dropped in water like 1 month ago and nothing happened, but after 3 weeks I saw this error. When no service error started to appear, my phone sometimes was able to make or receive calls.
Any suggestions should be appreciated!
EDIT: I am using this iPhone as an iPod touch now and recently I noticed that every time I boot the device up it shows that Cellular Update Failed error even tho I do not have SIM card installed.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Very bad sign. so Modem Firmware is located on BB_CPU and if you are not getting the firmware its a few of the following that can affect this
  1. BB_PMU is not working right therefore you may not be getting voltage to power the BB_CPU
  2. There is a issue with WTR and it is messing with the voltages of PMU
  3. BB_CPU needs reballed due to corrosion
  4. BB_CPU has a internal short
Either way this is a Motherboard that will need a Microsoldering Tech to repair.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for suggestions!Is that BB_PMU and BB_CPU replaceable? And could Jailbreaking damage it?
댓글 달기
귀하의 답변을 추가하세요
The Overclocked CPU 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 180
