주요 콘텐츠로 건너뛰기
The Nikon D1X is a digital single-lens reflex camera (DSLR) made by Nikon Corporation and introduced on February 5, 2001.
1 질문 전체 보기
How can I troubleshoot my Nikon D1x - NO SIGNS OF LIFE...
I purchased a D1x from an auction and discovered the included Ni-MH battery included was dead, and would not take a charge. I had the EN-4 battery pack professionally rebuild at a local battery shop and charged with my MH-16 charger. So far, so good. Put the battery pack into the camera body and *nothing* happened! No lights, no sounds, no indicators - nothing :-(
I don’t suspect the battery as it meters out at just over 8v with a DMV after charging.
I don’t have a Nikon EH-4 power supply.
Does anyone have a pin-out for the front power supply input jack? Maybe I have a loose battery terminal connection?
Any other troubleshooting advice is appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Using the power supply connector on the front of the camera body, I was able to apply power using a bench power supply, and discovered the camera powers on :-) Now, I'm going to troubleshoot the battery box assembly to determine if there is an open circuit or broken wire somewhere.
댓글 달기
답변 1개
Try using a toothbrush with some drops of vinegar…and rub gently the battery terminals inside camera body
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jtheires 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 419
