주요 콘텐츠로 건너뛰기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
Motherboard change from 2017 to 2015 Model?
Is it possible, with all the connectors, to change a 2017 board in a 2015 housing of 12” MacBook?
Or are there differences?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
@frischeis - To clarify: You want to upgrade your 2015 system to the 2017 board or downgrade from your 2017 system to a 2015 logic board?
I want to upgrade.
댓글 달기
답변 2개
선택된 해법
Sadly, the display is not compatible between your 2015 system and the 2017 logic board. Apple introduced TrueTone in the 2016 model year.
In addition to cost of a new logic board is around $600 USD, it would be cheaper to locate a used 2017 system. I’ve seen them go as low as $400 USD.
이 답변이 도움이 되었나요?
점수 1
댓글 11개:
Thank you for the info! I have a macbook from 2015 with a defective motherboard. I would have the defective board against a 2016 or 2017 motherboard exchanged. Now I have no choice but to buy a board from 2015 because of the truetone problem.
And yes, I'll buy a used board - new is out of the question because it's too expensive.
@frischeis - Here's a used 2017 that's for sale for $320 USD !! Apple MacBook 12" Core m3 1.2GHz 8GB 256GB 2017 Rose Gold SCREEN BROKE (Parts) with a new screen Complete 12″ Display Assembly for a grade B or C you end up getting away with $200 ~250 plus your time you will only cost you $530-560
Thank you for the links. But I live in Germany. I already bought the defective macbook from 2015 for about $240. Everything works (including the screen). So I only need a new motherboard. Hence the question of a board from 2017.
What is different between the display from 2015 and the 2017? The connector?
@frischeis - The signal assignments
댓글 6개 더보기
댓글 달기
So I can not put a battery from a 2017 MacBook in a 2015 MacBook right ??
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
frischeis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 25
전체 시간: 1,915
