iPad not turning on after LCD + Screen replacement
I replaced the digitizer and the LCD on my ipad 5 and it was working perfectly fine. After a couple of days I noticed the adhesive had come off and having a bought some strong tapes, I decided to redo the work. I switched off the ipad and removed the old adhesive which came off easily and before testing just to be cautious, I connected the LCD and the digitizer cables and it would not turn on. I tried hard resetting without any luck and the device is also not being recognized by itunes in my PC. I am really disappointed as I had it working like a charm and suddenly its being snatched away. Are there any ways to try or is it completely dead?
좋은 질문 입니까?
Check for missing components around the connectors.
daniel 의
@tech_ni thank you for the suggestion, I am looking around the LCD and digitizer connectors and it seems normal to me. Could you tell me what components or where to look out for as I may not be looking correctly. I also noticed the board gets warm while on charge occasionally and tried resetting while on charge and still no luck.
Wilbus 의
