주요 콘텐츠로 건너뛰기
동일한 모델 번호(A1932)와 EMC 번호(3184)를 사용하는 2018년 후반 MacBook Air의 소규모 개선에 대한 수리 정보 및 안내서입니다. 이 모델은 트루 톤 디스플레이와 약간 수정된 배터리가 특징입니다.
20 질문 전체 보기
Replacing Battery, what about adhesive for speakers?
I’m looking to replace a battery on a 13” MacBook Air 2019. I looked at the take apart and it seems straight forward. My assumption is the new battery will have new adhesive. What about the left and right speakers though? I’ll have to remove the adhesive strips to get those out and looking at the take apart the adhesive strips look ruined after they are removed. Any suggestions on best method of securing the left/right speakers?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Greetings,
I am replacing the battery "right now" on a MBA 2019 True Tone & noticed the replacement battery does NOT have any of the adhesive strips mentioned. I plan to test a couple of solutions on reassembly ONLY IF NEEDED. 1st, I'll apply several strips of the 2 sided tape, (known as "Adhesive Strip kit used to secure display on iMac). NOTE: Tesa 61395 Tape available on the ifixit.com website;
Tesa 61395 Tape / "Good Stuff"! Some of the best available at any price!
Throughout the reassembly process closely watching for any battery movement to confirm. In the event battery slide / slipping is discovered, disassemble & place "Thermal Pad" custom cut into the 3 grooves on each side. Apply display strip tape onto the pads - reassemble. In the event keeping the battery safely in place; disassemble - remove all pads & tape. Clean & apply "Thermal Conductive Plaster". Silicone Viscous Adhesive Compound designed for just such a need. If Thermal Conductive Plaster is required I pity the individual that attempts to replace the battery in the future. I would also write a "warning" "permanent marker" inside (bottom case) alerting anyone's future efforts. At the very least providing information what to expect hopefully preventing serious damage. Many tech's reading such a warning would stop the repair and investigate.
It would require an extreme amount of movement before EVER CONSIDERING Thermal Conductive Plaster as a solution to ANYTHING that could POSSIBLY require a future repair.
NOTE: IMHO - Anyone working on digital equipment should make the above mentioned a part of your tool bag. Especially - Thermal Pads - 0.5mm, 1.0mm & 2.0mm, "thicknesses at the very least". If working on iMac(s) 2 sided display tape in roll rather than " custom cut" is considerably less costly. I actually find it easier to work with if you purchase a decent product. Thermal Glue is another essential but beware there is good and down right "miserable" products to be had. Thermal Conductive Plaster is a bit spend y & should only be considered when NO FUTURE DISASSEMBLY is the plan. A much better solution would be E6000 Adhesive Glue available from IFIXIT - E6000 Adhesive Glue A phenomenal silicone glue that "could be" separated if needed in the future -- "MAYBE". I absolutely LOVE E6000. E6000 has been a go to for many years & earned my respect! Over the years have learned many adhesive lessons the hard way...
I hope this helps,
Douglas Swinhart ~~ Semi-retired (4+ decades self-employed System Administrator / Configuration Specialist)
A clear industrial strength adhesive. Bonds metal, wood, fabric, glass, ceramic, and other surfaces. 이미지
제품
E6000 Adhesive Glue
$2.99
Custom cut rolls of Tesa 61395 double-sided tape for repair. 이미지
제품
Tesa 61395 Tape
$5.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ryan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 16
전체 시간: 686
