이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 3개:
How so?? You'll need to give us a bit more here. Does it not startup? What does the MagSafe charger LED telling you? Is it Amber or Green. Did you have a spill or bang/drop your system? Given its age have you had someone replace the battery?
Dan 의
i dint change the battery , do u the battery issue ? thxc buddy ,
ali92 의
Can you answer the other points of what I asked
>> Does it not startup? Do you hear the fan spin up?
>> What does the MagSafe charger LED telling you? Is it Amber or Green?
Its a matter of following a diagnostic process. A then B then C and onward...
If you want to just jump to Z thats fine but it won't necessarily get you to the to the best answer!
Dan 의
