주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Stuck in boot loop after entering passcode
Hi,
got a iPhone 6 that was not looping , after I put in recovery mode and then exited it the phone started normally and went to passcode screen, after putting in last digit of passcode phone froze amd then went into boot loop again. Re flashed the phone on 3u tools amd passcode screen come up, after entering passcode it froze again on last digit and goes back into boot loop.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
There could be a lot of reasons your phone is acting like it is. You should try another screen, battery and dock connector to rule out a parts issue.
You said you flashed it with 3uTools. I gather you had the retain users data ticked? If you previously forgot the passcode and entered the wrong one too many times this is what I would expect to happen.
If you didn’t disable the phone by entering the wrong passcode the problem will most likely be a fault on the NFC circuit on the logic board which would require a reputable repairer to fix.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
dan morrill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 715
