Short while restoring in recovery mode
This board always causes an error while restoring (usually error 4015 but last time it was error 9).
Log:
<Restore Device 0x7f8235cd1f70>: operation 80 progress 1
[12:09:55.6073] requested restore behavior: Erase
[12:09:55.6110] <Restore Device 0x7f8235cd1f70>: operation 80 progress 1
[12:09:55.6111] requested restore behavior: Erase
[12:09:58.6406] <Restore Device 0x7f8235cd1f70>: operation 18 progress 0
[12:09:58.8493] RestoreOS mode device disconnected
[12:09:58.8493] RestoreOS device removed before restored completed
[12:09:58.8498] recv(13, 4) failed: connection closed
[12:09:58.8498] unable to read message size: -1
[12:09:58.8499] Failed to receive message from device, might be connection problem with USB host.
I attached a DCPS and it draw 120 mA while in recovery mode. While restoring the current jumped higher than 200mA (my MM is broken so I could not see how much it really was) and stayed this high after this error occurred. I don’t think it’s normal behaviour.
What lines can I check that would produce this?
좋은 질문 입니까?
just one way: localize a short. Split the board, should be a twice easier :-) (you know what I mean).
bert.harmidomski 의
There is no way we can help diagnose this over the internet unless you can give more information.
• How did it become like this?
• Have you tested it in a known good housing to rule out parts?
Chris Stables 의
Originally this logic board had a short on vdd_main, which I have fixed. After joining the boards together, everything worked like for 2 hours and then it suddenly crashed and was stuck in recovery mode.
I think I didn't join the boards correctly. I was using a normal stove and a hairdryer. It seemed like a pretty good job for me. But probably there was too few solder left.
I now seperated it again and bought proper equipment, such as a heat gun and the correct solder to reball it.
Jonas Geschke 의
