주요 콘텐츠로 건너뛰기
2013년 9월 25일에 발표된 Samsung Galaxy Note phablet 시리즈 3 세대. 모델 번호 N9005로 식별 가능.
248 질문 전체 보기
Water Damaged Note 3
It happened a few months ago.
I woke up seeing my phone is still charging. I grabbed it and noticed it was unexpectedly hot. It was wet so i wipe it with cloth. But i also noticed there was already water on the inside so i immediately remove the battery, sim card and sd card. I put it in the rice for a few hours and got impatient and tried to charge it and a few minutes, it still shows no sign of life and i put it back in the rice once again and leave it for a day.
I woke up and immediately go to my phone and charge it for a few hours… still no signs of life. But i feel my phone warm as it charges so i thought my phone was still alive. I searched everything on how to fix it and i saw some videos about cleaning it with alcohol. I disassemble my phone carefully and got a toothbrush and an ipa 70 percent. Still doesnt work but they said use pure ipa 99 so i buyed one and disassemble it once more and cleaned it with ipa 99 and dryed it for today. But still it does not work. Im on an edge of giving up and my last plan is to dunk the motherboard and other parts or submerge the phone in ipa 99 please help me. Last note: it happened a few months ago and i tried using ipa 99 this week and still does not work
The motherboard looks clean, i noticed some salt thingy and i think thats a corrosion and cleaned it with 99 ipa. Charging port also have corrosion and cleaned it and the phone still not work
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi
Before giving up, try to measure the voltage on the battery terminals.
A working battery should have at least 3.8V. If the outpus is close to 0v, then the battery is dead. The phone will not start with a dead battery, even if the charger is plugged in.
Has the same problem with a Nokia phone. The phone got dunked. Lithium batteries have internal circuitry to protect against short-circuit. Once the fuse on the battery management module blows, it’s game over for the battery.
Good luck!
Bogdan
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hello its the guy who posted this i forgot my password on the main account. Anyways, i do not have any voltmeter. Is there more ways to revive my phone? Currently, im planning to buy a new battery but it would be a waste of money if it still don't work. Waiting for the response asap. Thank you for your suggestion and be safe everyday.
댓글 달기
귀하의 답변을 추가하세요
A concerned man 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 59
