주요 콘텐츠로 건너뛰기
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 질문 전체 보기
Screen white after replacement
Hi everybody
I had to change the screen of my Apple Watch 4 44mm. For that, I bought a locked watch with a perfectly working screen. After switching the broken screen of my watch with the working one, the replaced screen is only white. I checked the cables and changed the Touch Force sensor as well. The screen is still white. Does anyone have any idea why?
Thanks and greetings
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
Maybe screen curtain is active, have you tried to disable it?
"Use Screen Curtain on your Apple Watch
Use your iPhone to turn on Screen Curtain for your Apple Watch:
  1. On your iPhone, open the Apple Watch app and go to My Watch.
  2. Tap Accessibility > VoiceOver > Screen Curtain. This setting keeps Screen Curtain active whenever VoiceOver is on.
  3. To turn Screen Curtain off, repeat these steps."
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Did you find a solution? having the same issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DeFidel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 496
