주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
Boot loop flashing apple logo
I have a defect iPhone 11 Pro Max that didn´t show any signs of life. I could get it into DFU mode and also Recovery Mode with the screen detached. I bought a Replacement Screen and now it shows recovery mode on the screen. When I try to exit recovery mode i get stuck in a booting loop where the apple logo would flash and then it shuts down again. I was wondering if anyone had a similar issue? Restoring won´t work by the way (Errorcode 4013 in 3uTools). Can someone confirm this has to do with NAND ic? Or could it also be caused by faulty batterie or lightning port?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Error 4013 can be caused by a lot of things but mainly the NAND. It is caused by a loss of USB connection. The first thing to do with a phone like this is to completely rule out parts. You can do this by installing the logic board into a known good housing with a known good battery.
Once you have confirmed it is not a parts issue you would move to the logic board.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
We have several external battery chargers and keep most iPhone batteries in stock. It is an easy matter for us to plug in a fully charged battery without having to do as much disassembly to check for the same thing
댓글 달기
답변을 추가하세요
Toby 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 10
전체 시간: 657
