주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
Ripped of contact on print board
Hi,
While changing SSD drive I ripped of one of the small connectors just above the battery, what is the best way of repairing the issue. I already got the advise of finding someone to soldering , but this will be unlikely the small contactor is embedded in a plastic body.
I thought trying to keep connector on its contacts with the help of black electrical tape. When dismounting the parts at the opening there is such tape strip on top which covers whole the connection area.
Added link to the pictures.
Thank you for your suggestions.
Regards,
Marc
Update (01/21/2021)
Hi Dan,
Thank you for your reply, I hope the pictures are clear enough about the issue.
It is the contact marked J123V next to TP 6 on the first picture, the second picture is the part which broke off.
Regards,
Marc
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Need to see what you've got here to help you 기존 질문에 이미지 추가하기
댓글 달기
답변 2개
선택된 답변
The connector you broken off is the battery board data cable connector on the battery unit.
The easiest fix is just replacing the battery MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery following this guide MacBook Pro 13" Function Keys 2017 배터리 교체
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery 이미지
상품
$129.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi Dan,
Thank you so much for your answer.
But the sad and stupid side of the story is that the battery proposed on this website is more than double than the Market price here in the UK.
The market price for the battery is around £60 were on this website it is about £128.99 and unfortunately this difference is too big for my budget , adds to it that my previous employer left the UK and I am looking for new challenge.
I don't know if you know the people running this website, but with such price difference even with the excellence of service provided, they must miss out on quit a lot of business opportunity.
Maybe not too bad to make them aware of this.
Anyhow, stay safe and healthy,
Regards,
Marc
@marcvlo Did you convert the US Dollars to Pounds? I get £110 Pounds! I haven't seen this battery go for lass than that!
댓글 달기
Hi Dan,
Thanks for the follow up.
I put you here a screenshot of the price quote for this battery on the system.
regards,
Marc
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Marc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 87
