주요 콘텐츠로 건너뛰기
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 질문 전체 보기
Disyplay Issues after Changing Display-Unit (ipad Air 2)
After my old Screen cracked i ordered a new one and tested it - worked fine. Then i disconnected it again to reglue the homebutton etc. After connecting it again all i got were these white lines. Backlicghht seems to work just fine. I also tested another known good LCD - same issue. Is anything wrong with the LCD Connectors on the Board? Any ideas? Thank you in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
hello Chris,
did you disconnect the battery when connecting the new screen? A lot of iPad faults are caused by connecting accessories (the screen is one of them) at 12-16V. This is usually tragic. In the right hands (first rule of electronics: do not work on live current unless you are doing a test. Otherwise: never, never) sometimes it works. Only sometimes.
When connecting the screen - people try to plug the connector into the port, sometimes they wander ... moving a little left, a little right. Some use force ... believing it didn't pop in ... It kills iPads like yours. By moving the connector over the pins, you find those with signal voltage (0.3-1.2V) and sometimes those with power supply (3.8-16V). Imagine what could happen to the delicate electronics destined for 0.8V when you serve them 12, 14 or more volts.
How to fix it now ... it would be nice to check your new screen is still working fine. Connect it to another tablet (if you have the option, if not - ask a technician at a good repair shop) and test it. If it's ok, I can use it again.
Disconnect the battery as first thoing. If you have an idea of electronics, you can handle it. I will assist remotely :-) You will need a meter - check and write down the resistance of all pins in the video port (long vertical strip, two horizontal strips are touch ports). You will need to solder something, so a good soldering iron is required. If you don't feel up to it, find a good electronics - he will know what to do.
  • regards and fingers crossing :-)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris Schwinge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 14
