주요 콘텐츠로 건너뛰기
A1708 / EMC 2978 — 2016년 10월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다. Function Keys 버전은 Intel Core i5 및 Thunderbolt 3 포트 2 개를 포함합니다.
216 질문 전체 보기
Why do purple lines appear past 25 degrees?
My computer is showing large, vertical purple lines (and one grey/green one) but only when I open the screen past 25 degrees. When I close the screen below 25 degrees, everything works fine. I have had a few different problems with this computer in the past which have been fixed under repair programs (keyboard replacement and display backlight repair).
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
What does an external display show you? Do you see a clean image.
@danj ya it works fine when hooked up to my tv
댓글 달기
답변 1개
Well, thats a bit of good news! Your display is only effected.
You likely cooked your T-CON board which has been a problem in this series. Sadly, it’s been a big problem so you can only get new display assemblies!
Here’s the guide to replace it: MacBook Pro 13" Function Keys Late 2016
Here’s a bit more on the why Screen issues - white/negative screen fixes itself after update In your case the tilting of the lid is either cutting off the air flow or adding stress to the T-CON board connections.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Daniel Madden 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 117
