주요 콘텐츠로 건너뛰기
The Razer Kishi is a universal mobile gaming controller that fits most smartphone devices, designed to bring console-level control to your on-the-go gaming. It was released in June, 2020.
11 질문 전체 보기
Specs on the "button covers" (tactile domes)?
I am looking to replace/fix the D-pad and XYAB buttons so that they are less mushy. Is there any information about how these could be “fixed” with aftermarket components to make the buttons less mushy?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Jeff,
we have a guide in the making for replacing the D-pad. It should be live soon.
There you’ll be able to see the build of the D-pad and can experiment with different “mods” to it.
In the meantime you could bend the metal spring that pushes the pad back up to your liking or you might want to add a thin extra layer between the pad and its rubber part so the connectors on the rubber part make contact with less travel.
Good luck with finding the sweet spot and think about sharing any findings for others to learn and improve their gamepad from.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Looking forward to your D-pad guide!
I guess you’ve already checked it out. If not, here is the D-Pad guide:
Razer Kishi Direction Pad Replacement
댓글 달기
귀하의 답변을 추가하세요
Jeff 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 250
