주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Why does my iPhone sometimes dont respond
I have a 6 Plus that i’ve been using since launch in 2014. About a week ago i was using it normally when suddenly started to press something in the screen. It was the original screen from the box not a replacement. At the time i didn’t think of anything and just restarted the phone and fixed it. A few days later it started to not respond to touch. I put the display to sleep and turn it on it works again and repeats about every 5 minutes. Now it doesn’t respond at all. I was about to buy a new screen but decided to ask first as i think it might be a software problem as it started happening after i updated to ios 12.5.1. Do i need to change my screen?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This could be touch disease; it is amazing to have lasted this long without having the M1 jumper installed. The only way to know for sure is to try a replacement screen. You can search for “iPhone 6 plus touch disease” It occurs when a pad under the touch IC becomes Brocken from its trace. It is caused by the flexing of the phone.
 The repair requires the touch IC to be removed and a micro jumper wire installed. The cost is about $80.00
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Alright! thanks for your answer i think i'll try a replacement screen i made sure that the phone is not bent so i think it might be the screen as i have a small water damage a few years ago
댓글 달기
귀하의 답변을 추가하세요
Jason 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 33
