주요 콘텐츠로 건너뛰기
다양한 그래픽 카드
111 질문 전체 보기
Is this repairable? Capacitor and pad torn off.
A capacitor was broke off the backside of my asus 3080 when I was installing a waterblock. Wondering if this is repairable? And the best way to go about it. I'll have better photos Monday when my digital microscope gets here. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You should be able to build that pad up, if you cannot it looks like there is a veer beside it and you would just need to scrape the surface than run a jumper. I would put some leaded solder on the pad and use an iron or mini hot tweezers. Depending on what’s on the reverse side you might be able to put a bit of hot air as well as the iron if the solder will not flow.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I've seen something about using mg-8331 to rebuild the pads then you can solder to that. Do you know anything about this? It would seem to be the easiest way for my limited skills.
댓글 달기
귀하의 답변을 추가하세요
Grant Fisher 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 55
