주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
No power or charge
I got an iPhone X to repair which had a damage screen and did not turn on when connected to power so I opted for changing out both the screen and the lightning flex connector. Replacing both results in the same thing happening, I hooked it up to a USB voltmeter and the output goes every couple seconds from 0A to 0.08A. Using a wireless charger also doesn’t do anything although it says on the charger that it is giving charge. Could anyone help me in further addressing the issue and whether it is repairable without resorting to motherboard micro repairs. Thank you.
EDIT: the battery has also been replaced with no success.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
You have ruled out parts so this is most likely a board issue. You could try booting the phone with only the screen and dock connected and out of the housing just to make sure.
If you wanted to continue with this repair you would need to know if it has a power problem or data problem. This will at least require a:
·         DCPS
·         Multimeter
·         Connection cables
·         Microscope
·         Rework station
·         Board view software and schematics
·         Preheater and stencils for disassembly and reassembly of the top and bottom board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try to replace the battery. if that doesn’t work, it might be a board issue. but first, try to reseat the connectors.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Ah yes I forgot to add I already tried also replacing the battery
oh, alright. try to reseat the connectors. if that doesnt work, it might be a board issue.
댓글 달기
귀하의 답변을 추가하세요
Lorenzo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 89
