주요 콘텐츠로 건너뛰기
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
101 질문 전체 보기
PSP will not work without charging and also will randomly shut down
PSP will not work without it charging and even then will randomly shut down and factory reset. Ive changed the battery numerous times and checked the charging output which at first, the charger that came with it was not supplying enough power to charge properly. I got a stronger cable (one that is recommended for the PSP through Sony) still have same issue
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It can be an issue with the battery connector. The cable that connects the battery to the main board might by dirty and have corrosion which is causing the battery not to work. Get some isopropyl alcohol and clean the battery connector’s contacts and also the socket where the cable connectors. As to why it randomly shuts down I am not sure
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Al Feidt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 301
