주요 콘텐츠로 건너뛰기
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
28 질문 전체 보기
What is this part called (or part#) found on the resmed AirSense10?
It is found inside body of the unit where the reservoir goes and mates with it and the removable/replaceable elbow. It is only accessible after disassembly and once removing the air pump. mine is old and covered in calcium which i am cleaning now but would like to replace as it makes whistling noises while im sleeping which wakes me up every night! THANK YOU!!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Not sure about the part but my machine was whistling and I put a small bottle of water on it and it is quiet now, I also got tired of the face farts caused by the face gasket andtie4d a handkerchief around the mask so the handkerchief would cover the entire gasket area - no more face farts and I have been using thew same gasket for 4 YEARS and it is still in good shape. The strap system is the one that frustrates me and I am going to "line" the strap on the inside with fabric and \\\then zig-zag stitch it so it can't fall apart and still has the grip side so the velcro can grip it. The fabric should strengthen it enough so the strap won't fall apart. The hard part of the mask lasted at least 4 years and mine is the old full-face model and the adjustment part finally broke. I may have been able to fix it with the new ultraviolet glue but I didn't have the glue when it broke. All those parts are frustrating when they break and Amazon is the only place I have been able to find them
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi, would you post a picture or clarify further the handkerchief across your full mask. I was just thinking how a rubber band or something to hold the mask that wouldn't hurt might quiet things. The handkerchief sounds like a great idea but I need some help doing it, thanks
댓글 달기
I think it's part # 37310.. It is called "Air 10 Air Outlet Seal"
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brian Davidson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 21
전체 시간: 793
