주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2014년 4월 업데이트는 새로운 듀얼-코어 i5 및 i7 Haswell 프로세서를 장착하고 배터리 성능을 약간 향상하였습니다.
100 질문 전체 보기
MacBook Pro 15" Retina 512 GB SSD (2013) to be used on Air 11" 2014
Do you know if I can use my Macbook Pro 15” retina 512 GB late 2013 in my Macbook Air 11” Early 2014? Are they compatible and if so is it a simple case of swapping them or should I give it to a pro as they have to do something with the software too? Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Take the time to read this great guide The Ultimate Guide to Apple’s Proprietary SSDs
It depends on which generation your MacBook Pro is: Gen2 Early 2013 or Gen3 Late 2013
해당 답변은 도움이 되었습니까?
점수 1
댓글 8개:
I have a late generation 15' 2013 and an early generation 11' 2014
So the SSD is the same Generation! Plug and play from a hardware perspective! BUT! your version of macOS could be an issue are both using the same release? If they are no issues! If on the other hand they are not you can get into trouble with the Sierra or older macOS versions HFS+ file system Vs the newer APFS file system used in High Sierra and newer macOS's versions.
@danj Thank you.
@danj Is there a place you recommend to purchase the 1TB for the 15" Retina late 2013? I found Transcend on Amazon which is more expensive than the OWC.
@kkixi - I would only use a real Apple SSD, OWC or Transcend.
Don't forget to accept the answer - Thanks!
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
KKIXi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 45
