주요 콘텐츠로 건너뛰기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
20 질문 전체 보기
mac mini 2010 High Sierra Handoff or Airdrop activate
Hello guys
I want to use handoff or airdrop in my mac mini, do I need a new airport card?
If necessary, please provide us with a compatible list.
I've already tried Bluetooth dongle, but it's not activated.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Sadly, its just not possible to upgrade your AirPort. There are two aspects the hardware connection is very different between your system and the needed AirPort board and the OS level you require for your system won’t support it.
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
So I can't use handoff in my Mac?
Sadly no. Apple altered things enough to prevent it.
ok... :/ thank for answer
Hey, I used a beta version of the Continuity Activation Tool and it was activated
@ajsa124 - Did you read up before you used it?? How to get Continuity on an unsupported Mac
One of the biggest risks these days is RAT and Malware which your system was protected, using the tool puts your system ore at risk. I don't recommend using this tool instead if your system can support the newer AirPort board I would go that way. Sadly your system doesn't offer that as an option.
댓글 달기
답변을 추가하세요
TS Ryu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 297
