주요 콘텐츠로 건너뛰기
A1708 / EMC 3071—2016년 11월 출시, 이 MacBook Pro 13”는 OLED Touch Bar를 소개합니다. 듀얼-코어 "Skylake" Intel Core i5 CPU 및 Thunderbolt 3 포트 4 개 포함.
239 질문 전체 보기
No power on water damaged MacBook Pro
I have a 2016 Macbook Pro that was water damaged 6 months ago (water bottle spill in a backpack). Unfortunately, it was powered up without inspection and was fried. There is ZERO power getting to the laptop. Any first steps to check? Everything looks perfect in regards to the logic board, etc.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Letting it sit was the worse thing you could have done! So you’ll need to decide how much are you willing to spend on fixing this system.
Does it only need a battery? Does it need the logic board repaired or replaced? That may push the costs to the tipping point if it’s badly damaged.
What is your skill set? Replacing a battery is not overly hard but I’m sure your logic board has issues from sitting wet for so long. I would at least pull the logic board to inspect it for corrosion damage.
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
It was my daughter’s and she was going to throw it away so I thought I would give it a go. My skill set is above average. I don’t want to spend over $500-800. Past that and I might as well buy an older used model for $1K.
I was hoping to take it one step at a time and slowly replace parts until it gets too expensive.
What would be the first step? Buy a new battery and see if shows any kind of life? Is there a “first diagnostic step” when there is no power?
Try plugging in a replacement battery (don't install it, just plug it in) any life?
Take out the battery and see if there is any light on the charger after plugging in?
Also if you check your motherboard model number and post it here, maybe with some close-up photos, we could point you in the right direction.
@honakrisi - FYI - No LED on the charger you're thinking MagSafe.
You would need a USB-C power meter to see what is happening like this one USB-C power meter.
댓글 1개 더보기
댓글 달기
The first thing to go with water damage is usually the keyboard and trackpad assembly, and also the battery, the logic board as long as it wasn't a lot of water should be fine, at least with older retina and unibody MacBook Pro's. I would recommend ordering a top case and a battery. Then pray to whatever you believe in. Also do any of the chips on the logic board feel really hot when plugging it in. If so the logic board will need either a couple of chips replaced or the entire board. Also remove the logic board and check for corrosion as Dan said.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kevin Chenoweth 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 112
