주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 질문 전체 보기
Will fixing a metal plate to the back affect GPS reception?
We're making a child proof iPad case that will add two big handles to the side of the iPad by sticking a big plate of metal to the whole back. When it covers the black area of the GPS antenna, will it affect the reception of it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Rolf,
I don't imagine that your GPS will be greatly affected, if it is even affected at all. There are often much larger and thicker obstacles between you and your GPS source, such as walls, cars, people and several hundred miles.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks Philip! But why does Apple put the black plastic part there then? Must be for the same reasons?
I honestly couldn't tell you. I stared at one and didn't see anything significant and I don't see anything exciting about it in our guides. It's possible that it might house the GPS antenna to isolate it from shorting? But perhaps another user has an answer to it's functionality :)
댓글 달기
귀하의 답변을 추가하세요
Rolf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 742
