주요 콘텐츠로 건너뛰기
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
240 질문 전체 보기
iPhone Cellular antenna signal strength
I went on Amazon and got a lightning port flex subassembly.
The microphone which was bad, now works, but the cellular antenna reception performance is now way worse. I connected the round rf port connector on the lightning flex, but only cellular strength is affected negatively after the repair. When I'm outside, I get a weak signal but only strong when I drive by a cell antenna.
Following the ifixit, on step 65 of your iPhone 8, lighting connector swap instructions, I DID NOT scour any of the silver glue residue from the back case/cover where the lightning flex adheres to. Do you think this might act as a rf cellular signal insulator? Or is it a bad Amazon lightning flex sub assembly?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I haven’t done charge ports on the new SE yet but I haven’t cleaned the old silver adhesive off before and haven’t had any issues. Although I think the cause of your issues is the Amazon charge port. Retailers like Amazon, eBay, AliExpress, Craigslist, and Wish do not have quality control over the parts that are sold so most of the time you’re getting very cheap subpar quality parts. If the old port is still in tact, I would reinstall that one and see if there’s a change. If that fixes it, order a new premium port from Mobile Sentrix. I use them all of the time in my shop and they haven’t caused any issues.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you. I’ll give it a try.
댓글 달기
귀하의 답변을 추가하세요
Joe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 11
전체 시간: 235
