주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
313 질문 전체 보기
MacBook does not boot
Hi!
My Macbook Air 13” does not boot at all. The screen stays black and there is no sign of life at all. When I plug in the charger, it’s saying that it is charging (led goes orange) but the Macbook still won’t boot. Does anyone know what’s going on? I think it’s motherboard related, but before I order a new one, I want to be sure.
Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Replacing the motherboard fixed the issue. I want to thank everyone here!!
댓글 달기
답변 3개
선택된 답변
It could possibly be your SMC chipset i have encountered this many times, especially in the Mac Minis and in certain macbook Air models
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Thanks for your answer! Is this an easy fix? Or am I better off to replace the motherboard?
better off replacing the whole machine in my opinion it honestly depends on the amount of time and money you would be willing to invest
Alright good to know, thanks :)!
Replacing the motherboard fixed it! Thanks!
댓글 달기
가장 유용한 답변
Here are a few articles from Apple which may be helpful:
If your Mac doesn’t turn on
If your Mac doesn’t start up all the way
How to reset the SMC of your Mac
If you aren’t able to power on your system using these tips, you may have a faulty battery, charger, or DC-In board. To figure out the cause you’ll need to do some troubleshooting or take it in to a repair shop.
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
Tested it with different chargers and this didn’t work. All the resets are tried but no sign of life. If the charger is in, it should boot no matter if the battery is faulty, right?
@dan0 some devices require a working battery to boot and I wouldn't put it past apple to do this as planned obsolescence
That's normally true. In some cases I've seen a bad battery cause power on issues that weren't resolved until a new good battery was installed, but I don't think that's what's going on here.
Alright. Well someone is bringing in a known working motherboard. I'll test and see what happens :)
If you have a faulty charging circuit and the input diode is faulty, it will stop your laptop from turning on as it detects a reverse current flow towards the charger from the battery. Try to remove the back cover and unplug the battery but nothing else and then plug in the charger and see if you can switch it on.
댓글 3개 더보기
댓글 달기
Firstly, you may make some checks, such as indicator light, cable, power connection, display and so on.
Then, try running Disk Utility to fix Mac issues.
Or reset NVRAM/PRAM to have a try.
Following post can be useful to help you step by step:
https://www.minitool.com/data-recovery/f...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes, the indicator light is on (orange). And can’t run disk utility as it won’t turn on at all.
댓글 달기
귀하의 답변을 추가하세요
koppie007 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 17
전체 시간: 235
