주요 콘텐츠로 건너뛰기
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70 질문 전체 보기
Help with screen replacement adhesive
I have bought a replacement screen for my pixel 3a to change out my current, broken, one. The screen did not include any type of adhesive. I’ve seen multiple options online, for example the ifixit kit comes with either a custom cut out adhesive or tesa tape, I’ve also seen that some kits ship with some type of glue. What is my best option to re attach the screen?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Glueing it in is going to make it very difficult when it’s time to change the battery.
I’d use some adhesive strips like these:
[연계 제품이 누락 또는 비활성화 됨: IF180-007]
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hi Simon,
I would use B-7000 glue, which is a slow drying compound, that allows you to perfectly align your screen after replacement. It also cleans up well, leaving o residue on the screen or frame after assembly.These tubes come with a precision tip, which helps with the accurate application.
Hope it helps!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Simon Bottini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 16
전체 시간: 272
