주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 9월 21일 출시. Models A1921, A2101, A2102, A2104. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S Max"로 발음합니다.)
Replacement Screen Not Working
I purchased and installed a replacement LCD digitizer from Ifixit, upon turning the phone on the screen worked briefly along with the touch. Immediately after unlocking the phone it froze and turned off, turning the phone back on gets the lockscreen but no functionality of the touch and shortly after crashes again.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Ensure that all the connectors are cleaned with alcohol, and make sure that the battery is disconnected before you start connecting the display cables. Once all the display connectors are seated properly, then connect the battery and turn on the device.
If the issue is still persisting, try connect that screen to a different body or try a different screen on your device to see if it’s the screen or device that’s playing up.
Also check to see if any of the cables have been torn or ripped or damaged at all as any small amount of damage may be causing everything to stop functioning normally.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Marcus Fairchild 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 95
