주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
154 질문 전체 보기
it is cranking but want start
I bought a 2004NISSAN ALTIMA THAT WAS FIRING UP ON THE DIME NO PROBLEM BUT I SWAP IT INTO ANOTHER BODY WHICH IS A 2006 NISSAN ALTIMA BODY NOW IT IS CRANKING BUT WANT START BUT WHEN THEY POOR GAS OR STARTER FLUID IT CRANKS UP AND RUN FINE BUT AFTER TURNING IT OFF SAME THING TURNING OVER
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
So it will only turn over if you're actively putting fuel through the engine?
댓글 달기
답변 1개
가장 유용한 답변
Sounds like its not getting fuel. Make sure that the fuel injectors are working and the fuel pump. If the fuel pump isn’t working, your engine will never start.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Pamela 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 72
