Black ink cartridge cover
How do I replace the black ink cartridge plastic cover that has broken?
좋은 질문 입니까?
좋은 질문 입니까?
If you really want to fix this, you usually need to find a donor. Printers do not make sense to repair in many scenarios, so parts tend to be scarce or expensive if not both.
What you usually end up finding out in the attempt to repair printers inadvertently is even the donors tend to cost as much as a new model with ink that’s reasonable and doesn’t run out every 5 minutes, or at least a used commercial SMB laser can be had for similar money as the part and you’ll be way happier with it.
Look for a super cheap donor, or dump the printer. They’re genuinely economically unrepairable.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 61
댓글 1개
Is there any replacement part for this issue
cathy woods beasley 의
